Activity Forums Adobe Premiere Pro Un-Rendering BS
  • Un-Rendering BS
    Posted by Justin Goldberg on October 11, 2019 at 3:59 pm
    I need some help before I throw this software in the trash.
    I’m working with keyed out footage, which requires rendering to play back smoothly in full quality.
    The problem is that after rendering, I can do the simplest tasks and the footage un-renders, forcing me to do it all over again.
    I can understand that the footage un-renders if I place a clip over the rendered part of the timeline.
    Where I start to get annoyed is when a simple cut un-renders the footage, or placing new footage in a completely different area of the timeline does the same thing to the whole project.
    I’d appreciate some help and understanding.
    Thanks.
    Jon Doughtie replied 6 years, 10 months ago 2 Members · 1 Reply
  • Jon Doughtie
    October 12, 2019 at 9:55 am
    Pretty much normal behavior on many NLE’s, not just Premiere Pro. Timeline renders aren’t meant to be permanent, just to make playback on a variety of timelines possible on a variety of computer setups. To eliminate it within Premiere Pro, simply create the keyed composite shot with some handles, set in/out points, export it, import that to the bins, and drop the comped shot in your timeline.
    If it is chroma key, I often get superior results using After Effects to comp the shots. Once saved, I can go back into that AE project and make alternate versions later if I require them.
    Nature of the beast.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
