Activity › Forums › Adobe After Effects › UN-rename/restore renamed footage?
  • UN-rename/restore renamed footage?
    Posted by Ben Jordan on May 10, 2012 at 5:23 am
    I’ve imported several layers of an Illustrator file, and renamed them in the *Project* window. Is there any way to see or restore the original imported name of any renamed footage?
    I can see Illustrator name under the File Path column, but that not the original name as it was imported.
    thanks
    Peter Kmeť replied 2 years ago 3 Members · 3 Replies
  • Dan Fredley
    May 13, 2012 at 11:45 am
    • Select the item in the project panel.
    • Then look at the top of your project panel and you’ll see the name you gave the item.
    • Click on the name and you should see the layer number in parentheses
    • Manually retype the name in the project panel
    That’s the best I can do.
    Dan Fredley
  • Ben Jordan
    May 14, 2012 at 10:00 am
    Thanks for your reply. It’s actually just showing me the name I gave it (in parenthesis). Below you can see I’ve named it “1” and the dropdown is showing me which comps & layers in those comps (normal behavior), and the name that it is using in those comps (It’s showing “1” on each because I have not re-named it in those comps).
    I am trying to figure out which layer name it is in the Illustrator file, which has tons of layers. This happened also on a co-workers project, so I was hoping to figure out a way to retrieve that original imported name.
    (You can see some of the other original names in the project area below the highlighted file. The one I accidentally renamed originally had a similar name, ##/NA map layers named.ai)
    I exported as an XMP in hopes it saved the original name in there, but it did not (at least not in human readable form!).
  • Peter Kmeť
    August 29, 2024 at 8:23 am
    You can use simple script for this. (copy code below to text aditor and save it as .jsx)
    var selectedItems = app.project.selection;
    for (var i = 0; i < selectedItems.length; i++) {
    var item = selectedItems[i];
    if (item instanceof FootageItem && item.file !== null) {
    var originalFilename = item.file.displayName;
    item.name = originalFilename;
    In After Effect go to File – Scripts – Run script file – and open document you just created.
    It will restore names of all selected items in project panels.
    Original filename is stored in metadata but sadly After Effects dont have build in function to restore it.
