Activity Forums Adobe After Effects Un-precompose
  • Un-precompose
    Posted by Stig Olsen on June 25, 2014 at 8:26 am
    Is there a way to undo precompose? Sometimes I need to access the effect control of the nested layers inside a precomp and at the same time see the original composition.
    In Houdini this is made simple, while you can pin point the composition view while you dive into the nestet clips or other compositions.
    Then you can do changes in the nested clips while you can see how this affects the whole composition.
    Stig
    Brian Charles replied 12 years, 2 months ago 4 Members · 4 Replies
