Activity › Forums › VEGAS Pro › “Un-normalizing” all tracks
  • “Un-normalizing” all tracks
    Posted by James Maxwell on December 4, 2012 at 9:15 pm
    I have a project with hundreds and hundreds of audio clips and I accidently checked “normalize” on some of them. Is there a way to “un-nonmalize” all the tracks? The problem I am running into is that when you select multiple tracks and check “normalize”, all that does is toggle each clips state. If 4 tracks are normalized and 10 tracks aren’t, then if you select hem all and click normalize, you will now have 4 tracks “un-normalized” and 10 track normalized. It just toggles them. Is there a way to make all of them the same without having to click on every single clip and “un-normalize” them?
    Edward Troxel replied 13 years, 9 months ago 6 Members · 5 Replies
  • Matt Carlson
    December 4, 2012 at 11:14 pm
    Copy the event of the state you want (in this case “un-normalized”) then select any and all of the events you wish to change and right click/paste event attributes. Unfortunately this will also copy over any effects of your first event as well so ideally the only thing you have done so far is change normalization.
  • John Rofrano
    December 5, 2012 at 2:59 am
    [James Maxwell] ” Is there a way to make all of them the same without having to click on every single clip and “un-normalize” them?”
    Yup. You can do this in one click with VASST Property Assistant. It can set, unset, or ignore any property on any number of selected events. Just tell it to ignore everything except Normalize and turn Normalize off and it will do exactly what you want. Only $9.95 USD and in the interest of full disclosure I’m the developer of all of the VASST FASST Apps like Property Assistant. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    December 5, 2012 at 6:21 am
    I’ve got VASST Property Assistant and the Normalize works like a charm. Dead Easy.
    Nice one JR!
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
  • Aleksey Tarasov
    December 5, 2012 at 8:15 am
    Quick Properties can do that and much more.
  • Edward Troxel
    December 13, 2012 at 6:38 pm
    Yeah, Yeah, and so can Excalibur…
    Edward Troxel
