Activity Forums Adobe After Effects Un-animated noise…?
  • Julian Sixx
    October 14, 2006 at 4:40 pm
    hi
    just render out the frame you want and re-import it
  • Madison
    October 14, 2006 at 5:00 pm
    You can use TimeRemap. Just click on layer in the timeline (Ctrl+Alt+T).
  • Roland R. kahlenberg
    October 14, 2006 at 5:45 pm
    Auto Noise will create noise on every frame. There is another Moise plugin that doesn’t auto-animate. Have a look-see in the sub-menu, under effects->noise.
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backrops with Adobe After Effects project files
  • Mylenium
    October 14, 2006 at 5:47 pm
    For ultimate control use Fractal Noise (set octaves to 1, it’s sufficient)and scale it down ’til it’s very small. Variation can be controlled using Evolutions.
    Mylenium
    [Pour Myl
  • Denys Glagoliev
    October 10, 2019 at 12:53 pm
    Choose Effect > Noise & Grain > Ad d Grain. Then go to “Animation Speed” parametr and set it to 0.
