Activity › Forums › Blackmagic Design › UltraStudio 4K with Thunderboltâ„¢ 2
Posted by Bruce Colgate on November 11, 2013 at 11:33 pmHowdy.
I read that BMD has released the UltraStudio 4K with Thunderboltâ„¢ 2, which seems to be a physically different product, though externally visually identical, to the UltraStudio 4K with Thunderboltâ„¢ 1.
The press release says it is immediately available through resellers, but it appears the resellers are either not yet selling the product, or are not differentiating the versions (see, for instance, B&H).
Please, does anyone have info on this?
With thanks,
– Bruce Colgate
Zack Stoff replied 9 years, 4 months ago 9 Members · 15 Replies -
Bob Zelin
November 12, 2013 at 2:26 amHi Bruce –
https://www.1sourcevideo.com/Home/HomeThis is 1 source video. They are the exclusive distributors for Blackmagic in the US. Call them, and ask them “where is it”. If they don’t have it, no one will, because B&H and everyone else gets it from 1 Source.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
maxavid@cfl.rr.com -
Bruce Colgate
November 12, 2013 at 6:14 amHi Bob!
Thanks for that. Will do.
Hope you’re doing well.
– Bruce Colgate
Gunter Hemeleers
November 20, 2013 at 4:06 pmHi Bruce,
it won’t be thunderbolt 2.
nobody can release a device with thunderbolt 2 before apple does.
until then any unit you can buy is thunderbolt 1 -
Bruce Colgate
November 25, 2013 at 6:31 pmHi Bob,
The fellows at 1SourceVideo were very accommodating. This was the response:
“Yes, these units are shipping. Here is the Blackmagic Design part number: BDLKULSR4K2”
Putting that in B&H’s search box now yields the correct device.
With thanks,
– Bruce Colgate
Bruce Colgate
December 6, 2013 at 4:58 pmJust got the Ultrastudio 4k TB2 version today. The TB2 badge is printed on the box in red in the upper right corner. Be advised you’ll need your own IEC power cable (none in the box), and like the multibridge before it, has a noisy little fan that will probably make it the loudest thing in your edit suite.
– Bruce Colgate
Jim Wiseman
December 9, 2013 at 10:05 pmDoes the Thunderbolt 4K have one or two Thunderbolt ports for pass through to daisy chain HDs and computer monitor at end of chain? Have seen photos with both one and two TBs. Current diagram on Blackmagic site shows two, which I must have as I only have one TB connection on my Macbook Pro 17 early 2011 Sandy bridge. Thanks in advance.
Jim Wiseman
Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1.3, Premiere Pro 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe -
Alex Gerulaitis
December 10, 2013 at 4:00 am[Jim Wiseman] “Does the Thunderbolt 4K have one or two Thunderbolt ports”
Two ports according to specs and press images. It’s UltraStudio Express and some other BMD products that only have one.
— Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
Jim Wiseman
December 13, 2013 at 9:11 amMine arrived today with the 2 ports, same model # with 2 at the end. Will be trying it out this weekend. Bruce, what are you running it on (computer) what OSX and what Blackmagic driver? Was going to 10.8.5 and 9.9.3 as a start with the newest, (except for Mavericks, want to give that some time). Have Mackbook Pro 17, early 2011, Sandybridge, an approved computer. OWC Accellsior 960GB flash in Helios 550/650MB/sec in Thunderbolt 1 case, + RAID 0 and 5. Mostly would like any info on BM driver and OSX. Maybe a new Mac Pro later this coming year.
Thanks.Jim Wiseman
Soeren Schlotfeldt
December 17, 2013 at 10:22 amHello Jim.
I Have a Mackbook Pro 17, early 2011, too and
I’m thinking to buy the Blackmagic Ultra-Studio 4K 2.I want to Connect the Blackmagic US to the Thunderbolt-
Connection of my Macbook and a DVI-Display via
an Adapter to the 2nd Thunderbolt-Port on the Ultrastudio.Did you check if that works?
Would help me a lot.
Soeren
Mrdavid Ising
March 30, 2014 at 1:56 pmHello,
Following on your threads here and I haven’t seen any conclusion to your question. Are the new 4k’ with thunderbolt 2 daisy chain-able?
Or if there was some sort of thunderbolt 2 hub that would allow several devices, that would be just as good.
Thank you
