Activity › Forums › Blackmagic Design › Ultrascope wierd waveform
Posted by Johannes Humaela on June 22, 2011 at 10:01 amAnyone know whats wrong with the waveform?
Using ATI Radeon HD 6850 with 10.2 drivers, Windows 7 x64
Hubert Arsoda replied 15 years ago 3 Members · 3 Replies -
David Catt
June 28, 2011 at 1:35 amWe have seen this problem before and was due the version of driver you are using.
Email nathan.gleit@filmsys.com who can help with the driver versions that work.
David Catt
Film Systems -
Hubert Arsoda
August 23, 2011 at 3:32 pmIt appears that you need an older driver like 10.2 or 10.7 to fix the issue. But with this resulted in a new problem, the video card (Radeon HD 6800 series) wont support drivers below 11.1. Do anyone know if there is a workaround or other way to solve the problem?
