Activity Forums Blackmagic Cameras ultrascope software via thunderbolt
  • ultrascope software via thunderbolt
    Posted by Ramil Pasibe on January 17, 2013 at 2:57 am
    Hi Guys,
    our blackmagic cinema camera just arrived and I managed to test the ultrascope software on a 13 inch macbook pro. The problem is that I cannot display all 6 displays for monitoring because of the screen resolution.
    Is there any other way aside from getting a 5 inch macbook pro to fully display all of them?
    thanks a lot.
    Chris Pearse replied 13 years, 8 months ago 3 Members · 4 Replies
  • Juan Salvo
    January 17, 2013 at 5:30 pm
    iMac will also do it.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Ramil Pasibe
    January 18, 2013 at 2:44 am
    Thanks Juan.
    Yeah it will do but bringing an imac on set is quite cumbersome. I guess there’s no choice but to go 15 inch then. Thanks a lot.
  • Juan Salvo
    January 18, 2013 at 5:12 am
    Not just 15, but retina 15. Need 1920×1080+ for 6 up display,
  • Chris Pearse
    January 18, 2013 at 8:08 am
    I tried UltraScope on my MacBook Pro Retina 13″. Whilst UltraScope will run, the performance is not great. However I see someone has mentioned recently on another forum that a program like Quickres might allow you to run all six scopes at once.
    The MacBook Pro Retina only allows up to the equivalent of 1680×1050, whereas the six-up view needs at least 1920×1080. Quickres allows you to use resolutions all the way up to the retina display’s native resolution. I can’t verify this myself right now, and I expect performance will be even worse, but maybe if you want to try it on this system, it seems like the only way to go.
    Chris Pearse
    Blackmagic Design
