Activity › Forums › Blackmagic Design › Ultrascope buggy
Joshua Helling
September 20, 2010 at 5:30 pmJust to recap here. Because it seems like this thread is really getting off track.
Mike, I’ve asked Hersh to email you directly for your system specs. Though I must say again, that I think you need to try to change you slot configuration.
You used semantics yourself when you took what I said about Ultrascope working in any TYPE of slot and turned it into it will work in ANT slot. As I’ve been trying to explain, this is simply not true.
To add to what Bob said about the rigs I used in the office here in the US let me clarify. I’ve personally tested the z400, 600 and 800, but it is not what I use. I have 3 custom built rigs (2 of which are based off a micro ATX form factor and are luggable). I use these in my office and send them all over the world to be used in tradeshows. In all of these rigs I had to play around with slot configuration to get it to work properly.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc. -
Jay Moffat
September 23, 2010 at 12:30 pmHo Joshua, would you mind posting the exact spec of your Micro Atx machine, I’m really keen to get a micro-atx setup of the scope and slot it into my edit desk, instead of yet another massive computer case.
Many thanks!
Jason
Margus Voll
September 23, 2010 at 12:32 pm
