Activity Forums Compression Techniques Ultimate Way to Compress For YouTube?
  • Craig Seeman
    July 16, 2013 at 1:19 am
    I’m not sure what you mean by “standard” guidelines but these are what they recommend.
    I’d suggest using the 1080 50,000kbps settings for best results (overkill in many cases).
    https://support.google.com/youtube/answer/1722171?hl=en
    Note the rest of the settings such as High Profile, CABAC, 2 consecutive B frames, GOP half the frame rate.
    Also note your source quality matters. Shooting on a Red Epic and using a ProRes HQ master file is going to look better than a consumer AVCHD camera. Recompressing an already compressed file is also going to look bad.
