Activity Forums VEGAS Pro Ultimate S vs Vegas Pro Production Assistant
  • Ultimate S vs Vegas Pro Production Assistant
    Posted by Bruce Quayle on September 10, 2010 at 11:37 pm
    Hi All,
    Just read a disturbing post that suggests that Vegas only uses a single core when processing.
    I was under the impression that although Vegas does not use the GPU (Vegas 10 aside) for preview and/or processing, it did indeed use whatever multiple cores are available. In other words, the i7 quad processors would be put through their paces.
    Would someone please clarify as this makes a huge difference to what specs one should use for a new computer?
    Many thanks,
    Bruce
    Harold Brown replied 15 years, 11 months ago 4 Members · 5 Replies
  • Bruce Quayle
    September 10, 2010 at 11:39 pm
    Sorry – my last post should have been titled as above!
    Bruce
  • John Rofrano
    September 11, 2010 at 12:26 am
    Vegas Pro will use all the cores you can throw at it. if someone is seeing only one core used, it is because they added an FX that is not multi-threaded or a render type that is not multi-threaded and that forces Vegas to only use one core, but Vegas itself will use all of your cores.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Norman Willis
    Hi Bruce.
    Mine uses all four cores.
    I think it is an abnormal condition if it uses only one.
    Norman Willis
    http://www.nazareneisrael.org
  • Bruce Quayle
    September 11, 2010 at 12:32 am
    Thanks for your clarification on this. I was panicking a bit ’cause I had just ordered a new laptop specifically with the i7-840 processor.
    Cheers,
    Bruce
  • Harold Brown
    September 11, 2010 at 6:50 pm
    Regardless if Vegas used all cores or not I would still order a multi-core processor. The operating system uses them.
    Harold
    __________________
    http://www.BhagaVideo.com
    Check out my published DVDs at
    http://www.edellismagic.com/Previews.html
