Activity Forums VEGAS Pro Ultimate S bitrate calculator for DVD
  • Ultimate S bitrate calculator for DVD
    Posted by Gary Abraham on June 27, 2011 at 6:44 pm
    Hi
    I used the Ultimate S bitrate calculator to create an Architect stream for DVD and it worked perfectly to fit a 2 hour 7 min project onto a DVD. Normal settings created a 6.5G file and did not fit, of course. I’m confused because the file is 5.2G based on the Ult. S calculator and it created successfully on a 4.7G DVD. And it looks great! Did Architect do an addition compression during burning? Just want to understand.
    Regards,
    Gary
    Nigel O’neill replied 15 years, 2 months ago 2 Members · 1 Reply
  • Nigel O’neill
    June 28, 2011 at 2:46 am
    DVDA will sometimes do an audio recompression which should only take a few minutes before creating the IFO and VOB files, but if you are experiencing hours or compression, DVDA may also be recompressing the video. This is not a desireable outcome. If you search this forum for Mark’s bit rate calculator and 2 pass variable bit rendering, you should be able to work out what you need to do.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
