Ultimate S 4 Photo Montage Dissolves
Posted by Chris Walsh on December 15, 2008 at 6:25 pmAnyone know how to just use the standard dissolve in the Photo Montage of Ultimate S 4?
John Rofrano replied 17 years, 9 months ago 3 Members · 3 Replies -
Mary Waitrovich
December 15, 2008 at 8:27 pmI assume you are in the command tab for Photo Montage, right?
click the Edit List Button in the Transition FX section. open the Sony Dissolve part of the list, select Additive Dissolve and Click Add>> to add it to the list on the right.
When you click Okay, it should be the only plug in showing and will be applied when you click apply at top.Regards,
Mary Waitrovich
UW-Madison -
Chris Walsh
December 16, 2008 at 12:03 amThanks Mary…but what if I want just a plain old dissolve? I can’t select that under that tab…
John Rofrano
December 16, 2008 at 12:45 pm> Thanks Mary…but what if I want just a plain old dissolve? I can’t select that under that tab…
Crossfades (i.e., plain dissolves) are the default. Don’t add any transitions and you will get a crossfade where the events overlap. Just keep the Apply Transitions option unchecked.
~jr
http://www.johnrofrano.com
http://www.vasst.com
