Activity Forums Apple Final Cut Pro Legacy UK Widescreen problems
  • UK Widescreen problems
    Posted by Jamesworsley on June 27, 2006 at 12:43 pm
    My final work must be 16:9 for UK widescreen.
    I’ve recieved a bit of info in the After Effects forum but am still a little confused.
    Should my sequence settings be 768 x 576 4:3 Anamporphic 16:9, or should they be 720 x 576 5:4 anamorphic 16:9.
    Even though screen is square pixels and tv is rectangular, should it be looking correct in FCP, or should it look squashed?
    James
    Justin Coleman replied 20 years, 3 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    June 27, 2006 at 12:47 pm
    What’s the source video? DV? then it should be PAL DV anamorphic, and it shouldn’t look squished in FCP at any rate…
    Jerry
  • Jamesworsley
    June 27, 2006 at 1:16 pm
    I’m not using any DV footage, just cut out graphics in photoshop, animated in After Effects…although i fear i’ve messed up the settings through out.
  • Peter Wiggins
    June 27, 2006 at 6:38 pm
    720 x 576 anamorphic 16:9
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Justin Coleman
    June 27, 2006 at 7:16 pm
    I usually use the 1024 x 576 Composition setting in AE 6. 720.576 is the frame size of DV and 768×576 is the ‘FULL’ UK TV frame size for SD TV. If you want 16:9 version, yes they should be ananmorphic.
    I’m sure you can adjust the project settings in AE if you are not sure.
