Activity Forums Adobe Photoshop UI is too small on Photoshop CC 2015 on 4K Monitor
  • UI is too small on Photoshop CC 2015 on 4K Monitor
    Posted by Chris Kay on June 5, 2016 at 7:36 pm
    I just bought an ASUS ZenBook, which has a 4K screen. I installed Photoshop CC 2015 yesterday and I noticed that the UI is way smaller than I am used to. I have set scaling to 200% (if I set it to 100%, the UI goes from being very inconvenient to unusably small). I have set the text UI to “Large,” but it makes no difference. What can I do?
    Reggie Sutton replied 10 years, 3 months ago 2 Members · 1 Reply
  • Reggie Sutton
    June 5, 2016 at 10:45 pm
    Hello Chris Kay. I had the same problem when I purchased my Microsoft Surfice Book pro, and the same problem my 4K monitors.
    There are only two options that I know of that’s available at this time.
    #1 you could sckil down your monitor to 1080 P That’s should be in your display setting.
    #2 Is a little more involved. Follow these instructions to the letter. I hope this helps you like it did for me.
    How To Make Adobe Software Display Larger On High Resolution Monitors
    https://www.youtube.com/watch?v=l4GCfugE0xQ
    Adobe App Scaling on High DPI Displays (FIX)
    https://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
    I would also consider leaving a donation for this information.
    I hope this helps. Peace & blessings.
