Activity › Forums › Adobe After Effects › uhmmm need sugestion…after effects
Posted by Josh Alvia on August 21, 2010 at 1:42 pmuhmm ok straight to the point…. \
its a rendering thingy…having trouble making file size smaller…i usually use a compressor i think during rendering iintel indeo video 4.5 i think…fixed my problem…now after reformation from xp to win7….cant find that compressor(i think)….
any sugesstion how to make the file size smaller and still hava a better quality..thnx in advance 🙂Steve Roberts replied 16 years, 1 month ago 3 Members · 5 Replies -
Todd Kopriva
August 21, 2010 at 4:39 pmYou can choose from a huge number of codecs (encoders) for compression. Which one you choose depends on exactly what you’re doing with your movies. No one codec is right for all situations.
So, what are you doing with these movies?
See this page for some basic information on compression using After Effects and Adobe Media Encoder.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Josh Alvia
August 22, 2010 at 12:22 amim making some text effects and other effects…
not editiing movies.. -
Todd Kopriva
August 22, 2010 at 3:37 amYour choice of codec and other output options depends on what you intend to do with the output movies. For example, if you intend to show them on the Web, H.264 might be a good choice; if, on the other had, you’re creating output for film-out, DPX might be a good choice.
Josh Alvia
August 22, 2010 at 6:23 amohhh… i see i see…so codecs depends on what movie im making….ok..thanks thanks 🙂
Steve Roberts
August 22, 2010 at 6:44 pmIt depends on the delivery medium. Where it is going. What is playing it back. How fast the pipeline is that is carrying the movie.
A faster delivery medium means that the movie can have less compression applied to it, so it can have a larger data rate: how many MB are going by per second.
Web? Modem? Broadband? Best guess?
Playback on hard drive only?The web can’t push as much data through, so the data rate (and file size) must be smaller than a movie that will only be given to someone to be played on that person’s hard drive. Hard drives can pump more data through than a web connection can. Make sense?
