Activity Forums Avid Media Composer UHD Resolutions for Ingest
  • UHD Resolutions for Ingest
    Posted by Brad Stanger on August 29, 2018 at 5:28 pm
    Working on a series which the client wants to work in Ultra HD.
    Footage shot H.264 3840 x 2160 150 Mbit/s.
    In a UHD project, what resolution should I ingest to keep as much info/quality as possible?
    LB, SQ, HQ or ProRes?
    13 episode series so storage is an issue.
    Glenn Sakatch replied 8 years ago 2 Members · 1 Reply
  • Glenn Sakatch
    August 29, 2018 at 6:42 pm
    Unless you are going full res, which it sounds like you can’t…then why bother?
    “Client wants to work in UHD” why? Are you pulling a bunch of keys?…then you might want highest res possible.
    If it is simply so you can say you did….well big whoop.
    work in HD, transcode to something easy to work with.
    uprez to UHD for final delivery. What does the client care what resolution the offline takes place in.
    I’d much rather my editor work at a low res, have their box be efficient and snappy, and then give me the best quality outputs at the end than worry about what resolution they cut the offline in.
    (Tell em its UHD and proceed :))
    Glenn
