Activity › Forums › Apple Final Cut Pro Legacy › Ugly rolling-stripe effects the image
  • Ugly rolling-stripe effects the image
    Posted by Tom Mackie on March 13, 2011 at 10:02 pm
    I shot a concert recently and when I aimed my Canon 7D at certain bright lights, an ugly, mechanical rolling effect would cross along my image. Why did this happen? I’m really hoping there’s a trick in post-production or a plug-in available to erase this effect. Here is a short example video of the ugly effect in general: https://www.vimeo.com/20991346
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jeremy Garchow replied 15 years, 6 months ago 4 Members · 4 Replies
  • Chris Tompkins
    March 13, 2011 at 10:41 pm
    I’m afraid you will not be able to remove that.
    I thought I was going to see banding from flashes.
    That, looks like low light, slow shutter, pointing into lights.
    Chris Tompkins
    Video Atlanta LLC
  • Michael Gissing
    March 13, 2011 at 10:46 pm
    Yes an ugly artifact. Did you see it in the LCD?
    My guess is the lights are beating at a rate that is a mismatch to your shutter speed. It doesn’t look like rolling shutter which distorts verticals but it is strange. Fixing it? I can’t think of a FCP plugin that might help. It might be a laborious job in After Effects but hopefully others will have ideas.
  • Tom Mackie
    March 14, 2011 at 2:09 am
    Thanks – it was LED lights I was pointing into.
  • Jeremy Garchow
    March 14, 2011 at 6:03 pm
    That looks like rolling shutter/jello cam to me. How loud was it right where you were? Seems to be a lot of camera shake, perhaps from blaring speakers?
    Maybe have a look at lock and load X. They say it might reduce rolling shutter.
    https://www.lockandloadx.com/
    If not, I’d look to effect all of your video to match that one. Very Gondry-esque. 🙂
