Activity › Forums › Apple Final Cut Pro Legacy › Ugly aliased text
Ugly aliased text
Posted by Chris Borjis on April 21, 2006 at 11:04 pmdoing a 20 point helvitica title card in fcp 5 and using its
internal titler.looks realy bad. you can clearly see aliasing on the text.
any idea how to make it look nice like if i did it in motion?
Chris Borjis replied 20 years, 5 months ago 3 Members · 7 Replies -
Chris Borjis
April 21, 2006 at 11:49 pmturning off the shadows fixes it.
But how can I do it WITH shadows and keep it nice?
I know clients will want it like that. -
Bouncing Account needs new email address
April 22, 2006 at 12:58 amYou should generally avoid using the native FCP title generators.
Instead, use “Title 3D” that is one of the other choices in your Generators menu.
April 23, 2006 at 1:54 pmAlso, you must only judge QUALITY on an external video monitor (never the computer monitor), and only after rendering at the highest quality setting.
Josh Weiss
April 24, 2006 at 3:27 pmI would also check your sequence settings. If the text is not animated a sequence with a field dominance set will make it look aliased. I would change your sequence setting, field dominance = none. This should clean it up 100%, let me know if it works.
Chris Borjis
April 24, 2006 at 4:43 pmThanks for the suggestions guys.
Yes, the text looks quite ugly and we are monitoring on our
pro sony SDI monitor that has 900 lines of resolution.as a test I made a DVD and the text looks way ugly there as well
and it should look nice so something is definitely wrong.Are you sure that field dominance should be zero?
These are being output to Digibeta and thus it must be interlaced.
Chris Borjis
April 24, 2006 at 5:21 pmTried the 3D Text.
Wow!
What a great titler. Couldn’t live without it for sure.
Boris Rocks.
