Activity Forums Adobe After Effects Expressions Typewriter with blinking Cursor/ disable Cursor
  • Typewriter with blinking Cursor/ disable Cursor
    Posted by Andrés Watzal on August 16, 2018 at 9:28 am
    Hello,
    I have this Code which gives me kinda a typewriter effect with a blinking cursor.
    3 Slider Controls named: “Speed” // Speed of Typewriter “Start At” // Starting Point and “Blink Speed” // well the speed of the blinking are necessary. With Values like 25, 3, 5 I got a nice working effect.
    CursorType = "_" // cursor type
    F = Math.round(time*effect("Blink Speed")("Slider") % 1); // Blink Speed
    L = text.sourceText.length;
    T = time*effect("Speed")("Slider") - effect("Start At")("Slider")*effect("Speed")("Slider");
    if(F ==1 | (T0) ){Fl=CursorType;}else{Fl=" ";}
    substr(0,T) + Fl
    I used a few tutorials to copy this togheter and get it working. Now I want to remove the cursor at the end.
    So I want it to Blink a few times in the beginning. Then type the word or sentence and not blink during this(as its already doing) and at the end the cursor and blinking is gone. I though about somehow reading out the current letter its at through index and then compare it to the text lenght ?? If possible without using any range selector.
    But I don’t know how I would add this. Is there also a possibility to get a Checkbox that allows me to switch the cursor at the end on and off.
    Thanks in advance
    Andrés
    Guido Giardino replied 7 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Andrés Watzal
    August 17, 2018 at 6:22 am
    This is acutaly the code. It erased the “<” “>” before.
    if(F ==1 | (T
    Andrés
  • Kalleheikki Kannisto
    August 18, 2018 at 9:10 am
    Try this
    X = text.sourceText;
    L = X.length;
    Cursor = " ";
    if (F==1 | T>0) Cursor = "_";
    if (T>=L) Cursor = " ";
    if (T>0) X.substr(0,T) + Cursor
    else Cursor
    Senior Graphic Designer
  • Andrés Watzal
    August 18, 2018 at 9:21 am
    Works perfect. Exactly how I wanted it.
    Thanks a lot!
    Andrés
  • Guido Giardino
    August 18, 2018 at 6:24 pm
    Hi Kalleheikki!
    Your expression works perfectly!
    Is there a way to make the typewriting goes backwards like erasing the letters after a certain time??
    Hope you can help me!
    Best regards!
    August 19, 2018 at 4:55 pm
    The simplest way would be to replace “time” with a slider that you can move forward and back so as to make time go backwards.
  • Nawaz Alamgir
    August 21, 2018 at 4:02 pm
    Hi
    if i wanted the cursor to blink once the type out animation has finished, how can i get that do work?
    August 22, 2018 at 10:47 am
    Use the original expression.
  • Guido Giardino
    April 9, 2019 at 3:09 pm
    Hi Kalleheikki!
    Just to say thanks for your reply! I just have the same question than the time I asked and I just read your reply! It works great!
    Best Regards!
