Activity Forums Adobe After Effects Typewriter effect.
  • Typewriter effect.
    Posted by Aaron Keeny on February 11, 2008 at 5:30 pm
    Im trying to create a typewriter effect, something a little more advanced then the basic typewritter preset in After Effects. Trying to create an effect like a typewriter is actually writing with the whole typewriter arm bar thing flying in and typing the text.
    i have an above average understanding of AE, and I am running AE CS3 on a mac power pc.
    any suggestions would be greatly appreciated.
    Thanks.
    Aaron
    Aaron Allsop replied 13 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    February 11, 2008 at 7:15 pm
    You could make a graphic of the typebar and typeguide and animate it coming up from the bottom over three frames maybe, with motion blur. Tweak it until you like it. Then render it and re-import it. Interpret it so it repeats as many times as you want. Lay it over your text and off you go. You might have to cut it for word spaces.
    For reference, if you’re as geeky as me:
    https://www.madehow.com/Volume-7/Typewriter.html
    Here’s the Murder, She Wrote open for a guide.
    https://www.youtube.com/watch?v=2aabssbby6Q
    And another classic in this vein:
    https://www.youtube.com/watch?v=RtNJSDLIhYY
    That’s one way, anyway.
  • Brian Berneker
    February 12, 2008 at 11:15 am
    Yeah that’s pretty much the deal, except I probably wouldn’t interpret/loop it, but just manually place instances on the comp. Typing is usually at an irregular pace, so the timing will have to be in step with your sound track.
  • Steve Roberts
    February 12, 2008 at 11:31 am
    I suppose it depends on how many characters are in the text.
    If there are a lot of characters, and Aaron wants it to be irregular, it may be a good idea to bring in the clip without repeating it on interpretation, then use time-remapping keyframes in pairs (start/end).
    Otherwise, we’d have of a layer for each instance. That could become unwieldy.
  • Brian Berneker
    February 12, 2008 at 11:43 am
    Yeah you have a good point there… Time remapping is a nice way around it.. good idea.
    Too bad AE doesn’t let you slip and slide multiple clips on the same layer like traditional editing apps… maybe in a future release they will add that and layer folders like they did in photoshop.
  • Simon Bonner
    February 14, 2008 at 12:06 pm
    Hi Aaron,
    I’ve posted a three-part tutorial on youtube showing one way of achieving this effect. If I’d started recording it after the time remapping method was suggested I may have gone that way, but ah well…
    Typewriter effect playlist at youtube
    Simon Bonner
    youtube.com/simonsaysFX
  • Ljudevit Posavski
    June 29, 2009 at 9:09 pm
    is it posible to add sound to animation you create in this 3 videos? If it is posible can you please tell me how.
    thanks
  • Aaron Allsop
    July 9, 2013 at 7:51 pm
    I bought this preset a while ago for just a dollar and it is really easy to use and looks really nice. It doesn’t give you the arm moving but it made it a lot easier than the one in after effects.
    https://gumroad.com/l/typist
