Activity Forums Adobe After Effects Typewriter effect in AE ??
  • Typewriter effect in AE ??
    Posted by Muhammad Othman on June 21, 2010 at 9:39 pm
    I ask about typewriter effect in AE.
    I want to change the writing direction from (Left to right) to (right to left) because I write in Arabic. Can I do that by this effect or any other way in AE?
    Muhammad Othman replied 16 years, 2 months ago 2 Members · 2 Replies
  • Jeffrey Kaplan
    June 21, 2010 at 11:04 pm
    I’m assuming you are talking about the Text Animation Preset? If you toggle down the animator, you should see keyframes under the Range Selector – just flip the keys around.
    Jeff Kaplan
    Point 360 WEST
    Animation & VFX Department
    http://www.point360west.com
  • Muhammad Othman
    June 22, 2010 at 10:03 am
    Thank u so much, I solved it by removing the 2 keyframes under “start” and setting its value to “0”. then, setting 2 new keyframes under “end”; the 1st is “100” & the 2nd is “0”
