Typefi AutoFit plugin – balancing columns
I’m having issues with the Indesign Typefi AutoFit plugin – specifically balancing columns ‘automatically’…I’ve got two text frames, linked bottom to top with autofit, and threaded together.
The text frame heights and widths are fixed (using the autofit palette) and it’s set to ‘keep frame size’.Now, everything i’ve read suggests that by putting two (or more) lines of text in the first column should force it to balance out so one line is in each frame – so, it hasn’t and I don’t know why.. can anyone help please??
Much appreciated,
Tim
