Activity › Forums › Adobe After Effects › TYPE-ON with Cursor
TYPE-ON with Cursor
Posted by Thomas Mcmurry on July 26, 2005 at 8:10 pmI’m looking to do some titles that look like they are typed on-screen with a cursor in front of each letter before it’s revealed.
I started to do them frame by frame, but I have too many to do. So I’m looking for an alternative to frame by frame.
I have not used the text tools in AE too much, but I heard this might be the place to start?
Any tips or tricks would be much appreciated!
Dotan Baytman replied 21 years, 2 months ago 6 Members · 7 Replies -
Aaron Strader
July 26, 2005 at 8:27 pmCheck the type preset animation gallery in 6.5. Go to HELP and choose Text Preset Gallery.
Look under mechanical. I think there’s one close to what you’re describing there.
-Aaron
https://www.stopfcc.com/
Knock it off! I like my radio and television the way it is… -
Dotan Baytman
July 26, 2005 at 9:34 pmHI
there is a plugin that does exactly what u want
im not sure if thats the right name
but i think its called “FINAL EFFECTS” -
Chris Smith
July 26, 2005 at 9:39 pmHmmm, I don’t remember there being one in the Final Effects set. Seems most final effects are included in AE 6.5 anyways as the CC plug-ins.
However the Image Lounge plug-ins has exactly what you seek. It does type ons with cursors of many different sorts. It will also auto blink them for you as well if you wish.
Just a type on is a cinch using AE’s text animations, but the cursor is a little bit more of a bear.
Chris Smith
https://www.sugarfilmproduction.com -
Filip Vandueren
July 26, 2005 at 10:52 pmThe text-animation preset including an underscore cursor is called:
Multi-line -> Word Processor
If you want to change the underscore into a full block:
add a scale- and anchorPoint-property to the first animator.
scale the underscore character way up (something like scale = [100,1600])
and then adjust the vertical anchorpoint untill it lines up. -
Jim Tierney
July 27, 2005 at 7:26 amOur Text Anarchy plugin set has a TypeOn plugin, which has a variety of cursors and additional options.
For more info:
https://digitalanarchy.com/text/text_main.html
cheers,
Jim——————
Jim Tierney
Digital Anarchy
http://www.digitalanarchy.com
415-586-8434 -
Dotan Baytman
July 27, 2005 at 1:22 pmHI again
sorry for the mistake i said i wasnt sure what plugin that was
but as chris said its in the image lounge plugin
