Activity › Forums › Adobe Premiere Pro › “type on” effect
“type on” effect
Posted by Nick Detomaso on January 23, 2007 at 12:04 amAnyone know a way to do the “type on” effect without a plug-in? Is there a better option than Boris Graffiti? Can it be done with After Effects?
Nick Detomaso replied 19 years, 8 months ago 4 Members · 4 Replies -
Aanarav Sareen
January 23, 2007 at 2:14 am[nick detomaso] “Can it be done with After Effects?”
Yes. It’s very easy to do so in After Effects.
[nick detomaso] “Anyone know a way to do the “type on” effect without a plug-in? I”
Yes. Keyframe the crop effect. Let me know if you need a demonstration on how to accomplish this.
– Aanarav
Aanarav Sareen
premiere@asvideoproductions.com
https://www.asvideoproductions.com/techtalk -
Steven L. gotz
January 23, 2007 at 2:56 amWhen you keyframe the crop effect, use Hold keyframes for each letter instead of smoothly changing the value of the crop.
Like this: https://www.stevengotz.com/examples/typewriter.wmv
I did this example so long ago in Premiere 6.x that the Clip effect was what I had to use. Now you would use Crop. BAck then cropping always zoomed. Now it is an option.
Steven
https://www.stevengotz.com -
Cal Johnson
January 23, 2007 at 3:36 amYou can do this easily in After Effects by applying the “Path Text” Effect to a solid layer, and then animating the “Visible Characters” value under the “Advanced” options. You’ll probably want to switch the default path from Beizer to Line.
