Activity Forums Adobe Premiere Pro Type from AE with Dynamic Link looks bad in Premiere
  • Type from AE with Dynamic Link looks bad in Premiere
    Posted by Ali Clark on April 16, 2014 at 4:31 am
    Using CS6:
    I have a title card created in After Effects with vector graphics (from Illustrator) and various type elements. It looks fine in AE and if rendered straight from AE also looks normal.
    If import that comp to Premiere with Dynamic Link, the quality of the type look jagged. I’ve checked to see if the “continuously rasterize” button makes a difference in AE. I’ve checked that my sequence settings are the same, both are 1920×1080, Square Pixels, 23.976. My Program window in Premiere is set to 100% at Full quality. I’ve rendered this out of Premiere to see if the final output looks better and it does not.
    Any suggestions would be greatly appreciated.
    Thank You.
    Ali Clark replied 12 years, 5 months ago 2 Members · 2 Replies
  • Sam Lanes
    April 16, 2014 at 9:28 am
    Is the quality preview setting in Premiere on full?
    Is it better if you render the graphic out of AE and then import as opposed to using dynamic link?
    https://www.aefromscratch.com
  • Ali Clark
    April 17, 2014 at 11:44 pm
    Yes, the quality is set to full.
    And yes the quality would be better if rendered and reimported but i’d like to be able to use the versatility of dynamic link. I don’t understand why the type appears jagged when using dynamic link.
    [Sam Lanes] “Is the quality preview setting in Premiere on full?
    Is it better if you render the graphic out of AE and then import as opposed to using dynamic link?”
