Activity Forums Adobe After Effects Expressions type animation, newbie to expressions
  • type animation, newbie to expressions
    Posted by Dina Saleem on March 17, 2008 at 8:25 pm
    Hi there,
    I was wondering, whether one of you can help me out with an expression.
    I am trying to make a text layer animation in which every character is adressed by an expression. I have some sample movies which can be downloaded from my homepage.
    I want to do this (sample movie is hand animated) http://www.dina-saleem.com/MoveGoal.mov
    If I apply a simple animator to animate the position value I get this :
    http://www.dina-saleem.com/Move.mov
    The problem is that I want the characters to have positive and negative y-values at the beginning and then stop at their final position.
    I applied a random expression to the position animator , which resulted in this :
    http://www.dina-saleem.com/MoveRandom.com .
    I also tried to define an array but I couldn’t figure out how to make each character take a value from the array as starting point and then start it’s position animation from there until it reaches y-value 0.
    Is that possibe at all?
    I really appreciate your help.
    Oh, and I am in a diffrent time zone, so please excuse me, if I don’t respond right away..
    Thanks a lot 🙂
    Dina
    Dina Saleem replied 18 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 17, 2008 at 8:55 pm
    OK – try this. Create a position animator with your desired maximum y offset. Add an expression selector and delete the range selector. Apply this expression to the amount parameter of the expression selector:
    decay = 2.0;
    seedRandom(textIndex,true);
    r = random(-100,100);
    r /Math.exp(time*decay)
    Tweak to suit.
    Dan
  • Dina Saleem
    March 18, 2008 at 8:54 am
    Hi Dan,
    I just got into work and tried out your expression. It worked perfectly as expected ;).
    Thanks so much!
    Dina
