Activity Forums Adobe After Effects Tying multiple Scripts together
  • Tying multiple Scripts together
    Posted by Daniel Elder on June 30, 2008 at 8:45 pm
    I have over 150 images that I’m working in a complex 3D space with, I plan to use two scripts I found through various scripting sites: 3D_Layer_Distributer.jsx and CreateSphere.jsx.
    The first script doesn’t create a null which it’s tied too w/ expressions, but the 2nd script does, I want my layers to move from the position/orientation created from the 1st script with my adjustments into a position/orientation taken from the 2nd script, but I haven’t been able to turn the second scripts expression into Keyframes, I’m assuming it’s because it’s tied to a null object and isn’t a mathematical equation.
    So my question is, how can I tie the positions of my objects in 3D space into the createSphere 3D Sphere with it’s position/orientation retaining it’s expressions?
    Daniel Elder
    producer
    http://www.luminair.com
    Daniel Elder replied 18 years, 2 months ago 23,252 Members · 1 Reply
