Activity › Forums › Apple Motion › [txt] outline issue – what is the status of the text engine. Outline gets cutoff
  • [txt] outline issue – what is the status of the text engine. Outline gets cutoff
    Posted by Helge Tjelta on December 12, 2009 at 9:39 am
    When putting on the outline on a text, it seems to cut of the outline. Looks like the outline is inside a max square around each letter.
    Type a 0 (zero) and put on a big outline for about 6. Watch the edges, no nice round circle at the top and the bottom, looks like it gets cutoff somehow.
    What is the status of the text generator in Motion, is it really good ? Or can we use other generators that also publish it self to FCP for the input.
    sincerely Helge
    Helge
    Helge Tjelta replied 16 years, 9 months ago 3 Members · 5 Replies
  • Mark Spencer
    December 12, 2009 at 2:16 pm
    I’m not seeing that issue, perhaps it’s the font you are using? I’m getting nice curved edges on my outline. I find Motion’s text engine to be quite excellent.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Arnie Schlissel
    December 12, 2009 at 4:16 pm
    select the layer that the type is in and make sure that it’s set to “Fixed Resolution” and that the resolution is the same as the Motion project.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Helge Tjelta
    December 12, 2009 at 4:58 pm
    well, fixed resolution does not do any difference.
    Helge
  • Helge Tjelta
    December 12, 2009 at 5:01 pm
    421_outlinemacpro.png.zip
    Inspect this one… check the corners and roundness, they are cut off.
    Helge
  • Helge Tjelta
    December 12, 2009 at 5:07 pm
    422_txtoutlineproblems.zip
    here is the link for all the different programs
    sincerely Helge
    Helge
