Activity Forums Maxon Cinema 4D two viewports/two camera views
  • two viewports/two camera views
    Posted by Peter Van aken on November 22, 2007 at 2:37 am
    I want to have the edit object appearing in two side-by-side viewports but have two user-determined views, where one of the object pair begins slightly rotated in relation to the other. The purpose is to be able to view my modeling in stereo 3D using an optical stereo viewer called a Pokescope. I will have to look aside to click on panel/palette stuff or use hot keys. The cursor will be doubled if it will appear, using this setup, in both viewports (will it?) but I think I could get used to it.
    Anyway, is this all possible?
    Thanks.
    PS. I know about SpatialView’s stereo plugin, but I can’t afford it and a stereo display.
    Arndt Von koenigsmarck replied 18 years, 10 months ago 2 Members · 1 Reply
  • Arndt Von koenigsmarck
    November 25, 2007 at 6:22 pm
    you can configure all views as you like.
    Just create 2 cameras and use them for the 2 different editor views (see Camera menue in each editor view).
