Activity Forums Avid Media Composer two vexing questions
  • two vexing questions
    Posted by Timothy Reed on December 27, 2008 at 2:31 pm
    Thanks people:
    I am on media composer 3.0.5
    I have looked thru the book and avid’s site but have not found answers to the following:
    How do I
    setup a visual timecode window for an entire sequence
    How do I slo mo a picture
    many thanks
    Tim Reed
    Red Reed Pictures
    Tim Reed
    Jeffrey Di lullo replied 17 years, 8 months ago 3 Members · 2 Replies
  • Jon Zanone
    December 27, 2008 at 7:38 pm
    [timothy reed] “setup a visual timecode window for an entire sequence”
    There is an effect in the effects pallet called ‘timecode’. I’m not sure where it is (I’m not in front of an Avid right now). It’s not realtime, but there was a real time TC effect floating around the web. Try searching for it…
    [timothy reed] “How do I slo mo a picture”
    Load the clip you want to slo-mo into your source monitor. Find a quick menu (I call it a hamburger menu ’cause that’s what it looks like… Usually, it’s between the source / record monitor) and pull it down. You can tear the menu away and place it on your work space somewhere if you’d like. In the menu, there is an icon that looks like an italicized media clip. Click on that, and you’ll get a dialog box. I like the ‘interpolate both fields’ selection, but play around and see what you like best.
    Jon
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Jeffrey Di lullo
    December 28, 2008 at 4:31 pm
    This link should help you with the BITC issue:
    https://www.avid.com/video/video_window.asp?videoID=242
    Have a great day!
    Jeffrey Di Lullo
    BBC&S Video Communicaitons
