Activity Forums Maxon Cinema 4D Two Splines into one object
  • Two Splines into one object
    Posted by Rick Sebeck on July 13, 2010 at 3:45 pm
    Hey guys — I’m a very basic C4D user. And I’m probably trying to do something basic – but I can’t seem to figure it out.
    I am trying to recreate a logo that has a bevel on it from PSD. If I use the path shape for the outside of the logo, extrude it, then apply a fillet, with hull inwards and constrain checked. It is close – but some screwy things happen. If I use the path shape inside of the logo, extrude it and add a fillet, again it is close but not perfect.
    If I bring in the two splines, set the outside back in z-space. Is there a way to combine the two spines so that it creates the arch(bevel) between the two?
    I’ve never really modeled things from scratch. So I’m stuck. What am I missing?
    Brian Jones replied 16 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jason Boos
    July 13, 2010 at 4:41 pm
    I assume each of the splines is on their own layer right?
  • Rick Sebeck
    July 13, 2010 at 4:42 pm
    Yes, I separated them into layers.
    Editor
  • Rick Sebeck
    July 13, 2010 at 5:03 pm
    Heres what I have. I just want to connect the two and create a bevel between them.
    902_p90xlogo.c4d.zip
    Editor
  • Brian Jones
    July 13, 2010 at 6:47 pm
    you can do it with a Loft. Put the inside and outside pair of a character into a Loft or do a Functions/Connect on the inside splines and the outside splines (separately). However, your splines need work. To work well at all the splines (and the embedded parts too) need to be going the same direction (blue to white/white to blue whatever as long as it’s the same) and for best results should have the same number of points. I fixed the P to work well in this example – assuming that’s what you meant by bevel.
    903_p90xlogoa.zip
  • Rick Sebeck
    July 13, 2010 at 6:55 pm
    That’s it exactly. Thanks Brian. The 0 is the the one that is most tricky – with the arrow cutting it off.
    Editor
  • Rick Sebeck
    July 13, 2010 at 7:16 pm
    I found a great tutorial describing what you mean… for those of you in the future who google this question!
    https://planetpixelemporium.com/tutorialpages/bevel.html
    Editor
  • Brian Jones
    July 13, 2010 at 7:44 pm
    good tutorial you found there.
