Activity Forums Avid Media Composer Two Source monitors?
  • Two Source monitors?
    Posted by Stephen Lewis on August 9, 2013 at 4:29 pm
    Check out this tutorial about dialog scene editing for Lightworks:
    https://www.youtube.com/watch?v=l62NOU3PsvY
    In that program, the editor is able to use two source monitors to mark clips from the scene coverage. Is there a similar feature in Avid? If not, what is the best way of switching between shots in Avid when assembling a dialog edit like this?
    Stephen Lewis replied 13 years ago 2 Members · 2 Replies
  • Michael Phillips
    August 9, 2013 at 5:12 pm
    Media Composer has had pop-up monitors since v1 in 1989. Option-double/Alt click source clip and it will becomes its own viewer/monitor. You can have as many as you want. You can drag other clips into those if you only want to have a set number of them available. I have also ganged different takes together when performances are close (faux multicam). But for scripted dialog editing, nothing really beats using ScriptSync. https://www.avid.com/US/products/scriptsync
    Even if you don’t purchase the automated syncing, you can still align takes to the script as needed and sync manually. May not be beneficial for a lot of scenes, but for the more complex ones with lots of coverage, it is fantastic.
    Michael
  • Stephen Lewis
    August 9, 2013 at 6:21 pm
    Thank you Michael! That’s awesome!
