Activity › Forums › Apple Final Cut Pro Legacy › Two small issues for mankind
  • Two small issues for mankind
    Posted by David Roth weiss on May 27, 2008 at 8:21 pm
    The following two tiny gotchas are eating up lots of my time lately.
    1) My USB mouse has several episodes each day wherein it suddenly loses some of its functionality and I have unplug it from the USB port and replug it in to fix it, even a cold or warm boot will not reset it. Anybody got a more permanent fix?
    2)Flash swf files always try to open in LiveType (is a mistake) and even do so after I set the “Open with” to open with MacProjector (Flash Player) everytime. Anyone know where to go behind the scenes to change file associations at an even deeper level than the Open with window?
    TIA,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
    David Roth weiss replied 18 years, 4 months ago 5 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    May 27, 2008 at 8:26 pm
    1) Try trashing your USB mouse prefs.
    2) When you get info on a flash file, click the ‘change all’ button to change all the swfs that you currently have and any future ones.
  • David Roth weiss
    May 27, 2008 at 8:33 pm
    Thanks Big J.
    Giving them both shots though I thought I had already done the second one…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • David Roth weiss
    May 27, 2008 at 8:47 pm
    Okay Jeremy, all SWFs are now properly working. Good one…
    Now, I can’t seem to find the USB mosue prefs, do you have a clue?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    May 27, 2008 at 8:53 pm
    Do you have a special mouse or did you install any software for the mouse you have or is it just an apple mouse?
  • David Roth weiss
    May 27, 2008 at 8:56 pm
    I have a very special mouse, or so I tell him/her every day so it won’t just up and quit on me…
    Its a Logitech cordless and I don’t think I had to install drivers, but I’ll check now. What were you thinking?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    May 27, 2008 at 9:02 pm
    Well, if you had to install software, I am sure that there’s preferences for it. ALso, if it needs software and you haven’t installed it, that might be part of your problem too.
  • David Roth weiss
    May 27, 2008 at 9:27 pm
    [Jeremy Garchow] “if it needs software and you haven’t installed it, that might be part of your problem too.”
    I think when I installed Leopard the mouse was simply working so I neglected to install the Logitech drivers. They’re in now…
    THNX Jeremy
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Eric Susch
    May 27, 2008 at 9:46 pm
    Your mouse may not be getting enough power. If you’re using a USB hub make sure it’s a powered hub. I had a similar problem with my keyboard when I first switched from a G4 to a G5 and a powered hub fixed it for me.
    ____________________________________
    Eric Susch
    http://www.LetsKnit2gether.com
    http://www.EricSusch.com
    Follow me on twitter @EricSusch
    Come and see our presentation at the
    New Media Expo in Las Vegas.
  • David Roth weiss
    May 27, 2008 at 10:02 pm
    Not using a hub Eric, but I suspect you’re right and the Mac isn’t sending a boatload of power around via the onboard USB ports.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • David Peralta
    May 28, 2008 at 3:16 am
    Hey David,
    do you need the drivers of the logitech mouse? I would uninstall the logitech LCC, its really crap. When I called tech support for a software that I need because i had the same thing happened and it knocked out settings, they told me that its based on Application Enhancer, so it will really screw around with your settings.
    You’re better off without the LCC! You dont need it anyway, it will detect it as a regular mouse without the drivers.
    Good luck!
    -Dave
    hmm… I wonder what this button does…
