Activity › Forums › Adobe After Effects › Two Seperate Wiggles – Same results
  • Two Seperate Wiggles – Same results
    Posted by Richshep on August 23, 2006 at 1:40 am
    I am trying to wiggle two objects seperately in the same comp.
    Each object is precomposed, and in their respective comps they have their own wiggle expressions (I’m using an adjustment layer with a wiggle expression attached to the Tile Centre of a Motion Tile effect).
    However, as I am using the same wiggle expression for each (wiggle(1,10,3); – I want the amplitude and frequency the same) AE6.5 generates the same “random” values for both.
    How can I wiggle each object the same amplitude and frequency, but get AE to generate different random variables for each? I’ve tried offsetting the adjustment layer in one of the comps, but this has no effect.
    Thanks.
    Dan Ebberts
    replied 20 years, 1 month ago
    2 Members · 1 Reply
  • Dan Ebberts
    August 23, 2006 at 3:07 am
    Add a seedRandom(seed) statement at the start of each expression (with a different seed value for each expression)
    Dan
