Activity › Forums › Adobe Premiere Pro › Two questions. Is it possible to save a transition as a preset? it is possible to change the default setting of a transition preset?
  • Two questions. Is it possible to save a transition as a preset? it is possible to change the default setting of a transition preset?
    Posted by Paul Copeland on April 10, 2015 at 11:03 am
    G’day.
    Newbie here.
    It seems to me that the default duration of a video effect dissolve transition is 1 frame. Well at least that is what I initially get when I add a dissolve transition. Is there a way to change the default duration of a transition?
    Is there a way to save a video transition as a user preset?
    Many thanks for your assistance.
    Paul.
    Ps. I am using Adobe Premiere Pro cs6
    Paul Copeland replied 11 years, 5 months ago 3 Members · 4 Replies
  • Oki Pienandoro
    April 10, 2015 at 1:06 pm
    Yes, make a box, and drag and drop your target effect.
    You can change duration of transition, and by default i believe it was 1 seconds, not 1 frame.
    You can also change the default transition to other kind intead of dissolve, IIRC, right click and set as default.
    Sorry for the english, not native speaker.
  • Joe Barta iv
    April 10, 2015 at 1:13 pm
    Go to the top menus, Premiere Pro > Preferences > General. There you will find you can set the default durations for the video and audio transitions.
    You can right-click on a transition in the Effects listings and make it the Default transition that will be selected when using the Command d shortcut.
    I don’t think you can save a transition with custom settings as a preset.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Paul Copeland
    April 10, 2015 at 1:22 pm
    Hi Oki.
    Thank you for your quick response.
    Best wishes for your video making and bye for now.
    Paul.
  • Paul Copeland
    April 10, 2015 at 1:23 pm
    hi Joe.
    Many thanks for your quick response.
    I have made the change and it works like a charm.
    Best wishes with your video productions and bye for now.
    Paul.
