Activity › Forums › VEGAS Pro › Two questions: Graphic Elements & Freezing
  • Two questions: Graphic Elements & Freezing
    Posted by Jforce on May 14, 2007 at 8:30 pm
    Hi all. I have two questions:
    1. How do I add graphic elements to a movie in Vegas? For instance, I want to be able to add an arrow pointing to someone.. or a thought bubble.. or a circle… etc etc. I don’t see any tools in Vegas to do that. If I have to create the image outside of Vegas in–say– Photoshop or Illustrator, how do I go about ensuring the object I create will be the right size and positioned exactly where I need it to be?
    2. How do I STOP the movie on a frame temporarily. I like the technique of freezing the movie momentarily while the narrator talks or something (a la Good Fellas).. and maybe even slowly zooming in on the freezed frame.
    PLease help
    Thank you
    If it doesn’t feel right, don’t do it. If it feels right, give it everything you’ve got.
    Terry Esslinger replied 19 years, 4 months ago 3 Members · 3 Replies
  • Edward Troxel
    May 14, 2007 at 9:13 pm
    [jforce] “How do I add graphic elements to a movie in Vegas?”
    A simply way is via a “wingdings” font
    [jforce] “How do I STOP the movie on a frame temporarily.”
    Take a look at the VELOCITY Envelope. Vol 1 #9 of my newsletters also talks about changing the speed of a clip.
    Edward Troxel
    JETDV Scripts
  • Jforce
    May 14, 2007 at 9:19 pm
    I hadn’t even thought to do it with a font. Great idea.
    But what about more complex graphics? Like the kind they do in reality shows with a thought bubble and text inside the thought bubble?
  • Terry Esslinger
    May 14, 2007 at 9:26 pm
    You could build a thought bubble in Photoshop and use a alpha channel background. Then import it into Vegas and place it on the track above your video. Make sure properties are set to alpha premultiplied (dirty) or you will not get the transparancy. You can then move the bubble where you want using event or track pan and crop. You could then place a text event on the track above the bubble and move it into position.
