Activity › Forums › Audio › Two questions about the Sennheiser EW100G3 system
  • Two questions about the Sennheiser EW100G3 system
    Posted by Noam Osband on March 9, 2016 at 5:07 pm
    Two basic user questions:
    1 – When i scan a new list, should i always take the first option it gives me? Is there any difference between them or all they all equally good?
    2 – in making sure my levels are good, I usually first check the transmitter, then the receiver. Is that correct?
    thanks!,
    noam
    Bruce Watson replied 10 years, 6 months ago 2 Members · 1 Reply
  • Bruce Watson
    March 9, 2016 at 8:41 pm
    [Noam Osband] “1 – When i scan a new list, should i always take the first option it gives me? Is there any difference between them or all they all equally good?”
    No reason to take the first one. It’s telling you that all of them should be clear-ish. IOW, any of them should work. I usually just pick one at random.
    [Noam Osband] “2 – in making sure my levels are good, I usually first check the transmitter, then the receiver. Is that correct?”
    Transmitter sets microphone sensitivity, which you want to set first. Receiver sets output level, which you’d want to set after. So yes, I think you are doing it correctly.
