Activity Forums Avid Media Composer Two questions
  • Two questions
    Posted by Roc Barbanica on August 16, 2005 at 12:11 am
    First, in Avid Xpress Pro HD 5.1-
    I used to be able to set the resolution button to total green, Now I only have all yellow or half yellow and half green- What happened?
    I have 4 gigs of ram so and a quadra pro 1400 video card 128.
    Memory shouldn’t be an issue….
    Second, I upgraded to the 5.1 version and now, in segment mode (fat red arrow) I cannot slide a clip anymore, it only snaps to the timeline bar or an edit point? What gives?
    All the best,
    Roc-
    Roc Barbanica replied 21 years ago 3 Members · 4 Replies
  • Michael Phillips
    August 16, 2005 at 12:15 am
    Are you working with 1:1 resolution? If so, you need a Mojo.
    Michael
  • Earle Nichol
    August 16, 2005 at 1:14 am
    Hey Rocman I’m in agreement with Michael on your first question…as for the second question I suspect in your timeline settings that the “DEFAULT SNAP TO is checked on, uncheck and you should be okay…just a nother change in the upgrade.
    Hope this helps
    Pearl
  • Earle Nichol
    August 16, 2005 at 1:15 am
    Hey Rocman,
    I meant”SPAN to EDIT” in your timeline settings.
    Sorry
    Pearl
  • Roc Barbanica
    August 16, 2005 at 8:57 pm
    DV25
    I was able to set resolution all green before and now, on the same video, I cannot.
    Any ideas?
    I got the segment issue solved- thanks.
    Roc-
