Activity › Forums › Adobe After Effects › two project windows in After Effects?
Posted by Andrey Sibiryakov on September 14, 2012 at 5:13 pmHello.
I’ve stacked with a heavy branched project.
Two project windows in After Effects would be so handy in my case.
Is there some way to manage it?Andrey
Andrey Sibiryakov replied 13 years, 10 months ago 4 Members · 6 Replies -
John Cuevas
September 14, 2012 at 5:35 pmYou can create multi-folders and import multiple projects into a single project, but there isn’t a way to have multiple project windows in AE.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Tudor “ted” jelescu
September 14, 2012 at 5:51 pmIf you mean two preview and timeline windows at the same time, you can if you have all projects imported in a master project. Open one comp, lock the preview window and double click on the second comp to open a separate preview window. You can then drag and position the preview window and the timeline panel for the second comp to a second monitor or position them (one by one) side by side or top -bottom with the initial comp.
Tudor “Ted” Jelescu
Senior VFX Artist -
Andrey Sibiryakov
September 14, 2012 at 6:08 pm -
Andrey Sibiryakov
September 14, 2012 at 6:28 pmSorry, have read quick and mixed up project and preview windows.
Bas Wijers
November 8, 2012 at 3:09 pmSo, is it possible?
I’m working on 15 infographic videos, all in one project. Would be mighty useful if I could have multiple project windows – just like in Premiere.
Andrey Sibiryakov
November 8, 2012 at 6:14 pmAlas, it is no possible.
I used some AEscripts script, that helped to import and update already built folder branch of footage on pc. That eased some things a little bit.
