Activity Forums Avid Media Composer Two Problems with Xpress DV
  • Two Problems with Xpress DV
    Posted by Jeff Jeffares on November 26, 2005 at 3:30 pm
    I am having 2 problems with a newly installed Xpress DV at one of my freelance jobs.
    1) The freeze function is grayed out and will not work.
    2) Any time I try to play back something in either the source or composer monitor, the video gets dark. Not too dark to see, but maybe around 75% of what it should be.
    Thanks for your help in advance,
    Jeff
    Jeff Jeffares replied 20 years, 9 months ago 3 Members · 3 Replies
  • Michael Phillips
    November 26, 2005 at 5:15 pm
    I don’t know about the freeze frame, could be a differentiation issue between products.
    The color shift issue is becuase of the Open GL card using the overlay function and needs to be adjusted at the OS Graphics Card level.
    See: https://www.24p.com/downloads/ATB024.pdf
    Michael
  • German Rubio
    November 28, 2005 at 5:42 pm
    It happens to me when i used to make a freeze frame.
    If you have the two monitors(the one wiht the clip on the left and the compositor on the right), you should choose the one on the left to make a freeze frame.
    I mean that you should decide the frame you like in the timelne window, and then make a match frame to choose the frame for freezing.
    This way it should work.
    LUCK!!
  • Jeff Jeffares
    November 28, 2005 at 5:45 pm
    Thanks guys! Both problems are now taken care of.
    Happy Holidays!
    Jeff
