Activity Forums Compression Techniques Two minute video at 20MB!
  • Two minute video at 20MB!
    Posted by Oscar Brightman on November 15, 2016 at 7:36 am
    Hello All,
    I have a client that has requested an MP4 of a two minute video to be delivered at 20MB so that it can be streamed from their app quickly. They have not specified frame size but the bigger the better obviously as many will view it on their desktops.
    I’ve never had to crush something this small and I’m wondering where to start – bit rate, aspect size (frame size really), etc. I work in Final Cut Pro X but I was going to use Handbrake to compress the HD master. Can someone give me a best practices workflow of which options to push for best and biggest result? Not sure if I should also mess with framerate, constant quality, etc. What is an acceptable low bitrate and frame size, etc. and what’s the best approach? Thanks in advance for any help.
    Here’s a photo of Handbrake controls available:
    10794_screenshot20161114at11.30.23pm.png.zip
    Oscar Brightman replied 9 years, 10 months ago 2 Members · 2 Replies
  • Craig Seeman
    November 15, 2016 at 5:23 pm
    File Size = Duration x BitRate
    There’s no secret behind that.
    Quality is a different matter. The larger the frame size the less bits per pixel which is lower quality.
    Acceptable quality is subjective so, assuming 16:9 aspect ratio, you may want to look at 1920×1080, 1280×720, 960×540, etc.
    High Profile and CABAC entropy yield better quality but may need more system resources to play. Most modern mobile devices can handle that. Older ones would struggle.
  • Oscar Brightman
    November 15, 2016 at 8:33 pm
    Okay, thanks for framing it this way. I thought there were more variables for file size.
