Activity › Forums › Lighting Design › Two kits.. need some advice
  • Randall Raymond
    January 7, 2008 at 2:18 am
    [Reggie Spires] ”
    I have two lighting kits in mind … I want the kit to be a multi purpose with a tilt to the green screen”
    I would go with the 6 light kit – be aware that you’ll be pulling close to 70amps. If it’s for a home-studio – you’ll need a room wired on 6-7 breakers – so add that electrical work into the cost.
  • Reggie Spires
    January 7, 2008 at 2:38 am
    could you elaborate .. I have to have a ?amp breaker for each light
  • Randall Raymond
    January 7, 2008 at 4:13 am
    [Reggie Spires] “could you elaborate .. I have to have a ?amp breaker for each light”
    15-20 amp breaker for each light. They show 11 amps for each. Lot of heat including the home wiring itself. You pretty much have to have each lamp on its own breaker. All I’m saying, is be prepared.
  • John Fishback
    January 9, 2008 at 10:49 pm
    Wattage = Volts x Amps so even at 110 vs 120 vac you draw a little under 10 amps per instrument. This means you can probably put two instruments on each 20 amp circuit. However, check your breakers. Depending on the age of the place, breakers could be 15 amps, in which case you can only put one light on each breaker.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Reggie Spires
    January 10, 2008 at 4:28 am
    It is a new house …swap so If I just put 20amp breakers on a two plug receptical I can run two lights on each one…
  • Rick Unland
    July 24, 2008 at 10:10 pm
    Please be aware that you cannot just change the breakers to 20 AMPS. The lines in your house have to be rated for 20 not just 15. If there are 15 Amp breakers presently in place, than have an electrician check to see what the actual lines are rated for. Sticking 20Amp breakers on 15 Amp lines is a disaster waiting to happen, especially with the amount of current you will draw with a couple of those lights.
    Good Luck
    Rick
    Sony VX2000, Beachtek DXA-4, Sennheiser K6/ME66, CamSling, Mini Rover, Canon WD58, CAVision Lens Hood, CobraCrane II , Steadicam Jr., Samson Wireless, Bogen Tripods & Heads, Adobe Premiere 6.0, Canopus Raptor RT, Pentium III 1 Gig, HP 200I DVD RW-R, and o
