Activity Forums DVD Authoring Two issues with TMPGEnc DVD Author
  • Two issues with TMPGEnc DVD Author
    Posted by Bill Morris on April 7, 2012 at 3:23 am
    I’ve got two issues with TMPGEnc DVD Author 3, and I’m finally throwing in the towel and asking for help.
    1. In building the menu, one item is larger than the others. It’s all one video file, so it can’t be a change in the size of the source. I’ve applied a new template. I’ve recreated the chapter point in a different location and rebuilt the menu. This one item stays larger. (I have two items highlighted so you can see and compare: the odd one is the bottom one.)
    2. When I try to build the DVD, I get an error “No stream available. (error code 0x80048001)” I’ve successfully built a DVD before with other projects (many times), and even with this project, though I’m not sure what, if anything, changed to make that possible. The error occurs during the building of the topmost menu – so, almost immediately.
    Help!
    Bill in Kansas City
    John Pugnale replied 14 years, 5 months ago 2 Members · 1 Reply
  • John Pugnale
    April 17, 2012 at 5:13 pm
    Bill,
    I have not used version 3 for quite some time, but I seem to recall have this issue before. Have you tried doing a shutdown and restart on the computer, then start an entirely new project, add the clip, edit the chapter points, then build a new menu?
    I know it is a pain. but I am betting that the project has somehow embeded a Widescreen thumbnail in its settings. I’d be interested to know if the same thumbnail position is widescreen on pages 2, 3, and 4. If so, then that’s a tell-tale sign. If not then that’s very strange.
    BTW, Authoring Works 5 has a lot of new features plus excellent file format support.
    Sorry it took so long to reply to your post. Not much traffic here for Pegasys TMPGenc Authoing users. It is really a slick, easy to use, yet powerful DVD authoring app. That said, it does have some limitations and quirks.
    John
    John Pugnale
    MVP Video Creations, Inc.
