Activity Forums Blackmagic Design Two intensity cards …one machine?
  • Two intensity cards …one machine?
    Posted by Scott Jensen on November 29, 2007 at 10:52 pm
    There was a similar post regarding using two different cards in a Mac, but what about two IDENTICAL Intensity cards on a Windows machine. I’m interested in capturing from two Canon HV20 camcorders SIMULTANEOUSLY to BM MJPEG HD or Cineform HD or as a last resort uncompressed HD. If this is not possible exactly what is preventing it? Is there a solution on the horizon?
    Scott Jensen replied 18 years, 9 months ago 2 Members · 2 Replies
  • Kristian Lam
    November 29, 2007 at 10:55 pm
    Hi Scott,
    What is preventing this workflow right now is that applications off the shelf right now will not address 2 capture cards simultaneously. Our drivers already supported multiple cards (even 2 of the same) in a single system.
    regards
    Kristian Lam
    Blackmagic Design
  • Scott Jensen
    December 1, 2007 at 3:31 am
    Thanks Kristian: while not the ideal solution, I might choose to use a switcher instead. Does the Intensity card accept input from an HDMI signal switch(er) such as:
    https://www.ramelectronics.net/html/HDMI-Switchers.html
    If I switch the video source input (to the switcher) between the two HV20 cams will the final result (video captured thru the Intensity) be glitch free?
