Activity Forums Adobe After Effects Expressions Two independent auto resizing boxes based off two lines of text
  • Two independent auto resizing boxes based off two lines of text
    Posted by John Pritchett on February 15, 2021 at 11:23 am
    I need to create a pretty standard sourceRectAtTime auto resizing box under text, but I need it on two lines, independently. As in Line 1 box is a different width to line 2 box.
    How can I apply the sourceRectAtTime on a box to only line 1, then a different box to line 2?
    Im also playing around with
    text.sourceText.split(‘\r’)[0];
    with no luck…
    TIA
    Filip Vandueren replied 5 years, 7 months ago 2 Members · 1 Reply
  • Filip Vandueren
    February 15, 2021 at 5:44 pm
    If you create a moment in time where only line 1 is visible and 1 where only line 2 is visible, you can use the sourceRectAtTime() for those specific time stamps.
    That time can be for example -1 and -2 seconds.
    You should use a textanimator that sets the scale of the characters to 0 at those times, setting the opacity to 0 does not remove characters from the sourceRect Bounds
