Activity Forums Adobe Premiere Pro two HDV export problems
  • two HDV export problems
    Posted by Sminnis on September 28, 2007 at 4:47 pm
    I’m a longtime Avid user now editing my first native HDV project in PP3. Editing has not been a problem, but I’m having a multitude of problems with export. I’ve done some searching in the forums for answers but come up short. For now, I’ll limit my post to the two biggest issues:
    1. When exporting as a quicktime or exporting to encore as letterboxed 4:3 SD, the letterboxing goes screwy on any shot I used the motion effect on. Whenever I did any resizing or rotation, the letterboxing shifts in correspondence to those effects. This is particularly problematic when I’ve used large JPEGs in a still sequence, which obviously required extensive resizing.
    2. When trying to export QT or back to tape, my audio is severely distorted. I’m not overmodulating in the timeline. In fact, I have a limiter set at -10 in my master track. Also, the audio sounds fine in MPEG2 exports.
    So far, the only way I’ve been able to get a project out is to export the MGEG2 widescreen to Nero and burn a 4:3 DVD from there (and even then I’m getting a little bit of contrast loss).
    Any help, especially in the form of specific export settings you’ve used successfully in the past, would be greatly appreciated. System specs below. Thanks,
    Stu
    Dell Precision PWS390
    Intel Core2 6400
    2.13GHz, 2GB RAM
    NVIDIA Quadro FX 3450/4000
    Sam In leeds replied 18 years, 11 months ago 2 Members · 1 Reply
  • Sam In leeds
    September 29, 2007 at 12:05 am
    One export setting that is always worth trying is the interlacing – if it is set to lower, try the upper and see if that makes any difference.
