Activity Forums Adobe Premiere Pro two graphic cards cuda primary required?
  • two graphic cards cuda primary required?
    Posted by John Riker on April 6, 2020 at 11:29 pm
    I have a a server that I do video encoding with and have a low end Quadro NVS 295. Encoding 4k video is taking way to long and picked up a Tesla graphic card. Premiere does complain it doesn’t like the Quadro. That said, if I kept the Tesla as secondary would that be a problem? Note for what it’s worth I usually remote into the server to setup the encoding.
    Also any info on how to setup the Tesla to encode with when adding it to the system already setup would be appreciated. Windows 10 and using Premiere Pro 2019 as 2020 keeps crashing my system.
    John Riker replied 6 years, 4 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    April 7, 2020 at 7:49 am
    I have no idea why you would keep the Quadro. It’s underpowered, unsupported and ancient.
  • John Riker
    April 7, 2020 at 12:48 pm
    So are you saying to take it out and just put in the Tesla? I was going to keep both and just use the Quadro for the primary display. Mine has connections on it but know some Telsas have no connectors and are just meant to be encoding engines and not display devices.
