Activity Forums Adobe After Effects Two for Rabinowitz (or Kramer, or both)
  • Two for Rabinowitz (or Kramer, or both)
    Posted by Darren Edwards on June 10, 2008 at 1:51 pm
    Hi guys,
    1. We thought this would clear up after upgrading to CS3, but
    it hasn’t… When working in SD/PAL, applying anything high-end
    – Trapcode, Magic Bullet, DigiDesign, etc. – immediately produces
    erroneous, field disparity-looking lines on the footage. Even on
    progressive material. Is this a PAL issue? or maybe a bit-rate
    issue? Obviously we’ve been through the ‘interpret’ sub menus
    a million times.
    2. What workstation do you use for the tutorials? 720p seems
    to render amazingly quickly.
    Thanks in advance,
    Darren.
    x-gf.com
    Aharon Rabinowitz replied 18 years, 3 months ago 6 Members · 9 Replies
  • 9 Replies
  • Kevin Camp
    June 10, 2008 at 2:19 pm
    for the first question. is opengl disabled in preferences>previews? make sure that the ‘use opengl’ option is unchecked and that accelerate previews is set to adaptive resolution.
    i’ll leave the second question for aharon or andrew.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Darren Edwards
    June 10, 2008 at 2:27 pm
    Will look into that that when I return to the edit suite.
    Cheers, Kevin.
    x-gf.com
  • Joey Foreman
    June 10, 2008 at 6:22 pm
    Darren, just because those guys (Kramer & Rabinowitz) have good video tutorials doesn’t mean that they’re the only ones on the forum qualified to help with your issue. The other moderators here all excel in their field, and you do them a disservice by implying that only the opinions of your preferred gurus will be welcome.
    Besides, Andrew Kramer is not even a forum moderator.
    If your question referred specifically to one of their tutorials, this would be more acceptable.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Hunter Christy
    June 10, 2008 at 7:32 pm
    for the record, they time lapse their tutorials when they screen record. so we really have no idea how long it takes to RAM preview.
    THE BiG HONKIN’
    “The Defenders Of Stan”-lots of after effects
  • Joey Foreman
    June 10, 2008 at 7:57 pm
    Oops, I totally missed your reference to the tutorials in part two of your question. I was focusing on your general technical concerns in the first. Sorry to have jumped to conclusions.
    Joey Foreman
    Editor/Animator
  • Bart Winckers
    June 13, 2008 at 11:17 am
    do you see these lines in AE or after you render it? If you see them after you render, try using another render output format, uncompressed for instance. I had this problem if I rendered out to dv pal.
  • Darren Edwards
    June 13, 2008 at 11:21 am
    It’s as soon as the plugin’s applied. Mostly noticeable at the
    edges, especially if the sky’s white.
    We did tweak the Open GL/adaptive resolution settings as mentioned
    by Kevin (above), but it’s still a problem.
    D.
    x-gf.com
  • Darren Edwards
    June 13, 2008 at 10:01 pm
    Here’s a screenshot example of the weird lines which occur
    whenever a high-end plugin is applied (in AE or PPro) to our
    DV footage.
    D.
    x-gf.com
  • Aharon Rabinowitz
    June 13, 2008 at 11:36 pm
    For the record, I never use 720P stuff in my tutorials. Always SD, and always Flashed forward in time so you don’t have to sit through a preview while I talk about why I love butterscotch or some other nonsense…
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
