Activity Forums Adobe After Effects Two comp windows open simultaneously
  • Two comp windows open simultaneously
    Posted by Eric Chard on September 18, 2011 at 3:37 am
    This is a really embarrassingly noob level of window management question, but:
    How can you get two comp windows open at the same time? I’ve tried, but the UI seems to resist (bastard!).
    I have a pre-comp that has a non-intuitive reaction to enabling constant re-rasterization, and I’d like to see both the final comp and the precomp at the same time.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 14 years, 11 months ago 61,997 Members · 1 Reply
  • Eric Chard
    September 18, 2011 at 3:48 am
    As is so often true, figured it out ten minutes later.
    The secret is to invoke a NEW viewer via the dropdown in the current viewer. Then you can drag it to wherever you want.
